#1 |
Standard Member
Identify this Turbo-Manifold Smart ForTwo (450)
![]() click: View slide-show. Turbo, varies angles/ views. One can pause, or enlarge the images. (Can not read the faded/ printed production numbers on the unit.). Clearly. It needs to be a 698 cc unit. How does one clean the unit before fitting - appreciating material should be avoided going into the turbo/ manifold. Block-off. (Petrol mixed with Paraffin?)(Brake cleaner?) Presume the metal gasket should be replaced - who and where is it best to source from. Any advice plus guidance here; is appreciated. Thank you in advance. Andreana |
#2 |
Standard Member
Re: Identify this Turbo-Manifold Smart ForTwo (450)
Have a look here >> http://www.evilution.co.uk/561
#3 |
Standard Member
Why don't you go to the place that you championed for remaps?
Surely they could help you ? |
#4 |
Smart Owner Since 2000
#5 |
Site Supporter
it's a 698 standard turbo, don't bother cleaning it...it'll be covered in 5h1t again before you know it, always worth changing the gasket if your feeling flush....merc is the best place to get it from......
#6 |
Site Supporter
Andrea - your car is a BRABUS, right? IIRC it's a different manifold for those.
__________________
#7 |
Standard Member
Hi, J500ANT Yes, correct Brabus. Also Passion (450) project. Thank-you; ever so much for the: *positive-input* - from those members. |
#8 |
Standard Member
#9 |
Standard Member
#10 |
Standard Member
Why don't you go to the place that you championed for remaps? Surely they could help you ? Contact: NON SPONSOR You will get an immediate reply! Plus ten years in the Smart business, from the outset, is testament in itself. Honest, efficient, reliable, affordable, professional, and a pleasure to do business with. *Excellent mapping systems* plus pre-car diagnostics. Others words only healthy cars will be mapped. Mr Andrew Shipp, is the owner, who can also deal with you. Hope that helps. Andreana. (In my opinion.). STILL A NON SPONSOR Them? From my other Post? Thank-you; for reminding me. Plus the rest of the Internet. To be honest they are flat out - fully booked! Not only do they do mapping, they also do car sales, service, and parts. To mention but a few. (Proven over Ten-Years.). Unlike yourself who sends me a PM/ BE A FRIEND? Why to solicit business off members/ myself? Don't bother me again! The so called friend-declined is on the way! Especially from the 'messages' I have had - to not touch you! As for others, laughing. Its more the case of the thick are confirmed: when they open their mouths and or type. The same. (*AMATUERS*). Post in my Opinion. Last edited by Messerschmitt Owner; 30-07-10 at 08:08 AM.. Reason: You know the deal! You agreed to the Ts&Cs |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
