Just finished up my EGR Delete on my grey winter smart, this is my fifth one I've installed this year. Dead easy to do once the EGR is removed, then its just a matter of installing the parts.
My smart is an Canadian 2005 Smart Fortwo CDI Coupe but it should be generally the same.
Ran out of black zip ties so I had to install the white ones for the time being.
- EGR Emulator from a member (stickman007) from CSC )
- 14cm long 1 3/4" Exhaust pipe with rolled bead to prevent from coming loose. (http://clubsmartcar.com/index.php?showtopic=26335)
- Blocking/cheater Plate from Ebay (Poland) (http://www.ebay.ca/itm/181215122428?...84.m1497.l2649)
- 2 Stainless steel bolts for the blocking plate.
- 2 2.5" Stainless steel clamps (for exhaust pipe)
